Firmware 5.113 x-10 problem
Hello,
just installed new firmware 5.113
This problem  of lost recorded messages ) in http://www.comfortforums.com/forum36/787.html appears to have gone away
But now Comfort can\'t handle received X10 commands correctly.
When i walk in a room (i have ms13 and an \"RF to powerline\" transceiver) the light doesn\'t turn on or, sometimes, it turns on 10 minutes later.
Comfort seems to have problems handling x10 inputs (receiving is OK, tested).
When i switch back to 5.79, all problems gone away.
Maybe useful informations:
1) The KT01 now emit some little but audible \"sound harmonycs\" from the circruity when receives/transmits data from/to Comfort.
2) The analog input of my temp sensor has gained 2 values from previous firmware (for esample: with firmware 5.079 i read 144, with 5.113 i read 146)
Thank you.
There does seem to be an intermittent problem with receing X10 codes which we are investigating
As you have 5.113 can you check if the Sunrise/Sunset Responses are occuring at the correct time, see http://www.comfortforums.com/forum36/839.html
Comfigurator does not support Sunrise/sunset responses yet, these must be programmed using Location (Eng Menu 7,4,1)
Sunrise Locations = 776 and 777
Sunset Locations = 778 and 779
A pair of locations are needed for each Response as the Response numbers are 0 to 1023
The lower byte of the Response number goes ito the 1st location and the higher byte into the 2nd one
The sunrise and sunset Responses should happen at the stated time in the Sunrise and sunset times in te Schedule > Sunrise/sunset page for the week, This is week 44
I\'ve switched back to 5.79, but next week i will try for you with pleasure.
It has been confirmed that X10 receive with Firmware 5.113 is intermittent. We have now fixed the problem and will be making the new firmware available for download/upgrade soon. The UCM05 is needed to do a firmware upgrade to Flash based Comfort firmware. The non-flash versions up to 5.079 are not affected, they can receive X10 signals fine
Has anyone else encountered this?
