Threads: 36
Does Comfort allow for multiple signon using RS232 interface ?
Threads: 885
I am not sure what you mean by this
If you sign in with a user code say LI1234, that is accepted with reply LU01 and the UCM will accept commands. If you sign in with another user code say user 2 LI**** the UCM will reply LU02. It does not really care who is signed in as long as there is a valid login
Threads: 17
I have built a little client/server app that works with the UCM/Ethernet to allow multiple connections (logons) to Comfort through one interface.
The client/sever runs on a PC and connects to Comfort. The other application(s) that you want to connect to Comfort would then connect to the client/server app. The client server/app looks exactly like Comfort to the application(s) connecting to it and just passes the traffic through from Comfort to the application(s) and the application(s) to Comfort. It has worked well for me, even using applications like WizComfort.
Let me know if you are interested.
Regards,
Clinton.
