Threads: 885
Could there be a problem with your network if it worked before?
are you able to ping the UCM/Ethernet
Threads: 36
Yes it can be pinged.
I tried via a router and a direct connection.
Threads: 219
Do you have a software firewall on your PC that could be blocking the traffic. I had similar problems and to prove it I temporarily disabled it to prove I could esatablish a connection. Once this was proven I then made sure the port was open in the firewall config.
Just a thought.
Threads: 36
I found some software on the net that does a port scan.
I did not find ports 1001 or 65535.
I went to my firewall settings and added these ports for DS Manager. I then reran the the port scanner software and I still don\'t see these ports.
Every other device is discoverable on my network expect my UCM/Ethernet
Threads: 219
Can you disable the firewall for 30 seconds and see if this works. If so at least you know 100% that it is the firewall blocking the traffic or you can move on to look elsewhere.
J
Threads: 36
I turned my firewall off.
Did an autodiscovery on DS Manager.
Nothing, no Device Servers where found
Threads: 36
How to I reset the Ucm to \'factory\' settings ?
