Pi
What are the specs for the CM4 that's included ? RAM/Storage. thx
(06-22-2026, 05:22 PM)srooks Wrote: What are the specs for the CM4 that's included ? RAM/Storage. thx
Golly are you still running you Comfort system we installed 20 years ago !
Hopefully its got a new CPU on latest non ARM version !
If I recall you had a door phone as well !
It's still running .. 25yrs ! Not the ARM version however. Have offloaded a lot onto HA now and HomeKit. Comfort is now just the Alarm and Sensor gateway :-)
Doorphone is now partially integrated into HomeKit.
the part number is CM4002000
Specs
  • Raspberry Pi Compute Module 4 Lite, with 2GB RAM, BCM2711, ARM Cortex-A72
  • 2 GB RAM,
  •  0 GB eMMC (Flash)
  • 1 x USB 2.0
  • 1 x HDMI
  • 1 x Ethernet  (RJ45)
  • 1 x SD Card interface
The supplied SD card comes with the Home assistant/Comfort MQTT  Image
Youy can also buy the CM4 yourslef if you want the eMMMC (Flash option) but you will need to load the Image yourself. Let uis know if you need to do that
