Threads: 5
I was on 8.013 and tried to upgrade to 8.030 - it just doesn't take it.
I then manually upgraded to 8.017 (which was never offered to me automatically) and it upgraded fine.
Any thoughts?
Mark
Threads: 885
The CM9001 ARM version is described here https://www.comfortforums.com/thread-5607.html
Please upgrade comfigurator to 4.0.4 by going to Help > Check for upgrades. The older versions did not detect the arm/nonarm versioopns correctly.
after upgrading Comfigurator please do a scan for module to dedtect the CM9001. Then do the firmware upgrade. Your Comfort versions should be the latest.If you did not buy CM9001within the last 1 year yours should not be the ARM processor
Threads: 885
Can you send your cclx file aftre scaniong for modules and saving, to support@cytech.biz
We will check it
Threads: 885
You are correct. the upgrade is not pointing to ULT 8.030. We have fixed the error. Please try again.
By the way if you do Download Firmware instead od upgrade ffirmware, the firmware cbf file will be downloaded. Before we fixed it the file downloaded was ULT 8.013
Thnaks for the feedback to both of you
