ULT 7.130-7.131 Beta
The changes for this beta firmware are below. Please download from https://www.cytech.biz/comfort_ultra_firmware.html
Bugs Fixed
  1. RS232 Command Do Action 190, Wait for Action  (DABE) after action 190 did not work
  2. OPTIMUM reset Outputs command did not work
  3. Action 73,16 get keypad ID did not work
  4. Sign in tamper did not work (from 7.109)
  5. Voice menu for Keypad Area 4,5 - did not work
  6. Command CM received wrong reply for control menu affects mobile apps
  7. Partition keypad disarm did not turn off siren when partition is disarmed if there is trouble alarm, until the code is entered 2 times
  8. Fixed BUG from 20/6/15 DA multiple actions  corrupted by security action eg bypass do alarm
  9. Fixed Bug Keypad Menu 4,5 Keypad Area (partition) annouced value was wrong
New Features
  1. Sensor Response is processed before sending Sensor report to rs485 bus to allow conversion before sensor report eg srNN
  2. Add action 159 conversion action - Needs Comfigurator 3.12
  3. When disarm any partition, and common siren is turned off, all partition siren outputs are turned off, and Keypad beeps are turned off on all keypads
  4. Scan for Modules -  when module does not respond to poll and causes Communications failure and if it is within the No of IDs of this type, reduce the number of modules of this type if this is the last ID of this type.
  5. Scan for Modules if id replies to u? query and it was not in eeprom, increase the no if ids of this type so a new module is automatically added without write to Comfort
  6. At reset, Comfort scans for modules to increase the number of modules for a module that was not in eeprom but is detected
  7. Eventlog for OPT can be increased to 600 if EEPROM size is increased to 256K bits
  8. For partitions, each partition has a siren output location. Requires CF 3.11.14
  9. 256 Nonvolatile flags and 16 nonvolatile counters for ULTRA not for OPTIMUM
ULT 7.131 beta fixed a bug with ULT 7.130 for action Get keypad ID
