RF Control For Roof Lights
I have a couple of roof lights with openers controlled by a stand-alone RF remote control handset (868.3Mhz).
https://www.dh-partner.com/en/products/rcr-11-2.html
Does anyone know how I can replace the remote control handset and control through Comfort? Ideally I would then operate via C-Bus switches.
I’m stumped with this one so any help would be appreciated.
You can try to open up a remote control and expose the buttons contacts.
Connect a Comfort Output to a RLY01 relay and connect the relay contacts to the button contacts that you want to operate. Use a Pulse action to the output to control the button of that remote - that would be like pressing the button manually
However if the button operation is toggle instead of  individual on and off, then you will not know if each action would turn on or off the lights
Would have to look at the control mechanism as it must have an alternative to the RF controller and use the mechanical switch to a comfort relay.....
** Spammer has been blocked **
