Comfigurator 3.10.11 has been released. To upgrade, open Comfigurator and go to Help > Check for Updates. You need to have an Internet connection
These arethe changes from Comfigurator 3.10.6
Known Bugs
Known Bugs
- [color=\"#ff5500\"]Cannot install on Windows XP. Windows XP users do not upgrade to this version. Windows 7 or above only for this version[/color]
- [color=\"#ff5500\"]File > Update Defaults does not work. This should update the default configurations and templates. To work-around, please unzip the files from this link https://www.cytech.biz/download_files.php?item_id=843 and save in the Comfigurator Installation folder. You do not need to exceute the files[/color]
- [color=\"#ff5500\"]In Zwave, after doing a Learn from Zwave, Flag mappings are changed into Counter in Zwave Mappings. However this does not afffect the actual mappings in UCM/Zwave, only the display in Comfigurator.To workaround, do another Read from EEPROM for Zwave. This bug was present in older versions of Comfigurator[/color]
- [color=\"#ff5500\"]Virtual Node in Zwave Configurator Virtual Node Info - SEND button n the right pane is missing from Comfigurator 3.10.9 [/color]
- Scan for SCS/IRIO detected RIO as IRIO
- Inserting \"Else\" in a Response between If and EndIf caused Exception
- Fixed Read from Comfort Exception when iRIO is present
- UCM/CBUS2 Limit of concatenated bytes is limited to 17 so that there is no overflow. Previous versions limited it to 18 bytes which is too much.
- In KT03 where write to KT03 failed to any reason, the message \"KT03 Upgrade timed out\" was changed to \"Write/Read to KT03 Timed out\"
- In KT03, if a button has a status for Zone > 64, read from KT03 caused the zone to be blank.
- Fixed BUG. After Module scanning, KP06 and KP04A modules which are removed from the system were not shown. They should be shown in red with the status \"Not Found\". Only Modules with properties in memory eg UCM/KNX, KP06, KT03 etc will be shown as Not Found. Modules that do not have saved properties will not be shown at all in the modules list if they are removed from the system.
- UCM/eHomegreen fixed scanning for modules problem where the scanned modules were not seen.
- For Logic Engine without voice, the warning that Vocabulary does not match before write to Comfort has been removed
- Support for IRIO
- Scanning for Modules has been speeded up greatly. What took up to 1 minute now takes only a few seconds, due to a new scanning method. This requires Comfort Firmware 7.093. Older firmware will still use the old scanning method. This is especially useful as more module types are added to Comfort which would increase the scanning times otherwise.
- Timers (in Names > Timers) has a field called Timer Status. The \"Show Status\" button will show the Timer as OFF or ON, and if ON, the remaining timer in seconds is displayed. This is a useful tool when programming and testing Timers.
- \"Clear Event Log\" button has been added to the Event Log window. It is good practice to Save the event log and delete it so that old events are not lost
- In System Information, \"Vocabulary Number\" eg 5, has been changed to \"Vocabulary Name\" eg \"English Residential\"
- The Action \"Send RS232\" applies to all UCMs, not just the general UCM, so that new commands can be sent to other UCMs which are not supported before.
- Send RS232 action in Hex mode accepts space as separator between bytes as well as comma
