how to reset comfort II ultra to factory reset
Hello pros , need help here . How to reset to factory setting because I am forgot enginer code either user code for comfort ultra II , me using k06 keypad . Please help me . Or how ca ln I retrieve the old or changed code . Thanks you so much .
Can you contact your installer? I suggest you to ask your installer to do so.
You could have kept a backup of your comfort programming with a UCM/USB or ethernet
Press the UPLOAD button to transfer your configuration to the U2 EEPROM in the UCM. This includes the user and engineer codes
see http://www.comfortforums.com/forum4/3419.html
If the programming is corrupted or your codes are lost, press the DOWNLOAD button to transfer the saved config back to  Comfort
Try pressing the DOWNLOAD button on the UCM anyway because there may be a default configuration with default code 1234
If 1234 can work then you will have to reprogram the system again
If that does not work then you need to get a new default U4 for your system
Let us have your comfort PCB serial number starting with P.. or C...
