Defaul panel
I\'ve got an old comfort panel,I think its a comfort pro. The keypad has no display. I\'m unable to connect using the configurator software is there a way I can completely default the panel using the keypad ?
Do you mean that you have lost the user codes?
If so you can use the Engineer code to reset the user code to 1234 as described in http://www.comfortforums.com/forum16/2357.html
You cannot default the whole program back to a blank system
Once you have your user code, you can write the default template to Comfort
Thanks for the help. I know the user code but ive taken the panel from 1 site and installing it some where else. Just wondered if I could default panel and start again from scratch.
Use Comfigurator and select a default template then write to Comfort to \"default \" it
Then start again to program with Comfigurator
