KNX 1 bit switching map to Comfort Away Arm not working
Hi expert,
I was trying to map KNX button to Comfort Away Arm.
But I is not working.
Besides that, then \"Learn\" function is not working too.
I am able to test the \"On\", \"Off\" by manually set the KNX address.
Please guide me on this.
Comfort OPT version: 6.028
UCM/KNX version: 6.112
Edit: KNX to Comfort is not working, but Comfort to KNX is working fine.
Thank you!
Quote:I was trying to map KNX button to Comfort Away Arm. But I is not working.
Can you explain exactly what you did?
KNX to Comfort?
did you assign group address Type = Arm to Away? as 1 -bit?
If so it definately will work especially as you say KNX to Comfort is working
Quote:Besides that, then \"Learn\" function is not working too.
The Learn function allows you to see the KNX group addresses as they are sent on the Bus. So you have to press a KNX switch while in learn mode, otherwise nothing will happen
Quote: KNX to Comfort is not working, but Comfort to KNX is working fine.
Did you assign any group address to Comfort to KNX?
How do you know it is not working?
These alarm conditions are sent  to the mapped KNX group address
The UCM/KNX Manual can be downloaded from https://www.cytech.biz/ucmknx_manual.html and shows how it should work
Thanks for your reply.
I think that is the problem from my push button because it is working when I send the 1-bit value from ETS Group Monitoring.
But not working when I configured my push button to \"Switching\" OR \"1-bit value sender\".
Will try to figure it out myself.
