12-06-2006, 01:04 PM
I went to a new install yesterday because Comfort had \'locked up\' - no response from keypads etc.
I checked the voltage (OK) and dorstation shorts!!!!! but these appeared to be OK - I did a manual reset (Yes the button is now almost inaccessoble under the LEM!!!!) the unit came back to life a few seconds later i had UCM RIO coms error on the keypad - I removed (Physical and from program) RIO and it came back to life again - i did all the tests i could think of to try and upset it - after1 or so i added RIO back in and once again did a load of tests with keypads and Rios and etc etc it appeared after 1hr or so to still be stable - I left it overnigh and phoned in this a.m and appears to be OK.
I enclose an event log which shows the RIO and also other coms ailures later - I can supply the ccl file (seperately if required).
Any ideas?
Any ideas?
