Unknown SMS code
I received SMS code \" (10210sqm) - OK ! \" does anybody knows what the meaning is of this code ??
Such a message is a reply to an incoming sms
I just sent an SMS (10210sqm) and got the same reply (10210sqm)- oK
This also disarms the system due to the sequence (10...
Did you send a SMS to disarm the system?
Thanks for your reply. I armed the system by (11) SMS and got the usual (11) - OK in reply. This SMS was send 11.00 am At 05.00 pm I received the SMS message (10210sqm)- OK If , as you say, the system disarmed than it was disarmed by it self. Normal disarm code is (10) so why (10210sqm)? What is sqm ??
sqm has no meaning
What the UCM/GSM does is to repeat the text message received within brackets and add OK
ie if it receives
(10210sgm), then it replies (10210sgm) - OK
There may be an error on the GSM network which caused the SMS messages to be corupted, I suspect
Thanks again for your advise. You probably right and just presume the Mobile network must have send a corrupt message. Last night I send again the arming code and got the normal response. Since then no more messages.
