UCM/KNX in Monitor Mode
The Monitor Mode tab in the KNX Comfigurator allows incoming telegrams from KNX to be displayed.
In Monitor mode, the KNX to Comfort mapping does NOT work
If you leave the Monitor tab that ends the monitor mode and KNX to Comfort commands will work again
However, we have found that if you log out or close comfigurator without leaving the monitor mode tab, then the UUCM/KNX remains in Monitor mode and KNX to Comfort commands will NOT WORK
We shall try to fix this in Comfigurator (currentlly 3.6.4)
In the meantime, please ensure that you leave Monitor mode always before leaving the UCM/KNX
The UCM/KNX Manual has been updated with this warning
https://www.cytech.biz/ucmknx_manual.htm...ory_id=107
KNX monitor mode - are you able to tell me what KNX telegrams are picked up.... In ETS there is a bus monitor which pretty much provides information on all telegrams on the bus.
I suppose what I\'m asking is will the KNX UCM pick up all telegrams or only selected ones?
The monitor mode will see all received telegrams, but not what is sent by UCM/KNX
