01-03-2013, 01:56 PM
i have connected the i/p with current sensor , But How to detect o/p status on event log?
01-03-2013, 08:19 PM
I think \'Output Status\' is not an Eventlog trigger event. See the Protocol Documentation for all events written to the log.
Ingo
01-04-2013, 03:06 AM
Correct, the event log is meant for security events only, not for automation
However ULT firmware version 7 has a new action Save to event log (need Comfigurator 3.6.2) in Response Wizard > Misc This action has a parameter 0 to 255 so you can add an action Save to EventLog 1 to the outputN Response The Event log will show the event recorded with the output or any other action This is good for troubleshooting purposes
01-04-2013, 03:32 AM
Ident,
Can you please send me the command format for this new feature, I couldn\'t find it in the latest protocol documentation. Also, from which firmware version will this be supported? Thanks, Ingo
01-04-2013, 04:03 AM
This is not a change in protocol, it is a new action code and so is found in the Action Codes Reference https://www.cytech.biz/product_details.php?item_id=147
Those with a gmail email account, can get access to the Cytech Resources folder which contains the updated manuals, documentation, software etc
01-04-2013, 04:13 AM
This action is supported in ULT 7.005
01-08-2013, 11:05 AM
thanks for reply ,
can i delete event log ? or adjust the time that i want to be saved ?
01-08-2013, 11:13 AM
You can delete event log using keypad, Engineer Menu 5 for event log, 0 to erase Event log
The time stamp in the Event Log is based on the system time You can adjust that using Program Menu 2 for date and time, or by Comfigurator Transfer Menu
01-08-2013, 02:30 PM
I make \"code=34,param=0\" for detecting o/p status OFF
And \"code=34,param=1\" for detecting o/p status ON my question is : how can i rename the text appars on event log (unknown event) to as example (light on) ??
01-09-2013, 06:00 AM
Copy the attached file eventlog.cfgx into your comfigurator\\config folder
This will cause the event log to show \"Custom Event # 0\" or other event number instead of Unknown event, 34 Custom Event means it is a custom event with parameter 0 to 255 You will have to know what each parameter stands for in the event log, as this is a method of troubleshooting events triggered by Comfort The new Comfigurator 3.6.3 will include the event eventlog.cfgx file |
| 5 Guest(s) |
