The beta version of Comfigurator 3.6.0 is available for testing by advanced users. This has more major improvements and new features which will greatly enhance the power of Comfigurator. The main changes are;
UCM Connection
The selection of UCM Connection has been improved. Go to Options > Settings. The Saved Connection Settings are now here (instead of Configuration > System Information). If \"Override Saved Connection Settings\" is unchecked the Saved Connection settings for Local Network and Remote Network are shown
Modules Tab
The Modules in the Modules Tab are shown in different colours depending in the status;
[color=\"#550000\"]GREY: [/color]Indicates that the module has not been found by Scanning yet, eg when the file has just been opened
BLACK: Indicates that the module has been discovered by scanning
[color=\"#ff0000\"]RED[/color]: Means that the module has not been discovered by a module Scan
[color=\"#00ff00\"][color=\"#000000\"]GREEN[/color]: [/color]Modules that have their ID changed but before the modules are reset to activate the ID change. This applies to modules with firmware version 7 and above
BLUE: After scanning, a new module has been discovered but the number of Modules has not been written to Comfort yet so Comfort does not know about the new module ID
New Modules Scanning Rules
Better rules for Module scanning to be described later
Changing IDs for Module Firmware version 7
Modules with firmware version 7 can have their IDs changed by dragging and dropping the IDs on the Modules Tab. This changes the IDs of 2 modules, eg UCM #1 can be dragged to UCM #2 position which causes the two modules at ID1 and 2 to swap their IDs
Sunrise/Sunset Times
The date of Monday of each week is shown so it is easier to know which week is current
New Actions
Reset Module action 118 resets the module at specified ID (firmware 5.222)
Save to Event Log Action 119 saves to Event Log - can be used to save any event to the event log
Log in /Log Out
Comfigurator does not log out automatically after any operation which cause it to log in eg Write, Read, Execute, Scan etc. This allows information in Monitor I/O to be seen after certain actions
Check for Comfigurator Update
Comfigurator will check automatically for a new version every time it is started and gives an option to upgrade the software
Also, in Help Check for Update will update Comfigurator if a new version is available.
Firmware Upgrades
There is a new and simpler firmware upgrade method. In Modules Tab, select the module and right click and select either \"Check for Firmware Updates\" or Upgrade firmware from Local File. \"Check for Firmware Updates\" will upgrade the firmware of the module from the Cytech server if there is a newer firmware available.
Comfigurator will decide the proper way to upgrade the firmware, either by Direct Connection to PC or by Comfort Bus.
Transfer > Firmware Upgrade only has 1 option, \"By Programming Cable connected to UCM\"
When Comfort, UCM and other modules have firmware version 7 ot above, UCMs and KT03 firmware can be upgraded by connection to Bus as well as by direct connectiob. This means that KT03 can be upgraded via UCM instead of by connecting to its USB port. However the upgrade time for KT03 by Bus will much slower, about 30 minutes compared to KT03 USB port which takes only 5 minutes. But this allows KT03 firmware to be upgraded remotely eg over the internet
KT03 Default Template
When a new KT03 is added, the kt03 default template kt03def.kt3x is loaded automatically instead of blank pages
IR Leaner
For ETH02, Increased buffer size to handle long IR codes or due to IR button pressed to long, so that this does not case an exception. Do NOT press and hold the IR button when learning IR codes
Bus Monitor
UCM Connection
Modules Tab
New Actions
Log in /Log Out
Firmware Upgrades
IR Leaner
Bus Monitor
- Bus Monitor will use the current UCM Connection Setting depending on whether Saved Connection Settings or Override Saved Conection settings is selected
- Fixed bug Bus Monitor changed the working folder for Comfigurator when a bus log is saved
- Fixed Bug Bus Monitor exception when 2 modules have the same ID
- Zwave
- Universal UCM
- Velbus
- Velbus unknown module causes cannot write to Comfort error
- Response numbers > max causes Alarm Type names to have FF in front so SMS alarm Names are blank
- When Bus Monitor file is saved, it changes the working folder for comfigurator and exception will occur when going back to Comfigurator
- Bus Monitor has exception when running Bus Analyse with 2 modules having the same IDs
- During Firmware Upgrade by Bus, UBF6 error message did not end the upgrade operation.
- DAC5 send command in Zwave does not use escape character 15
- Virtual Inputs for KNX cannot select zones 65 to 96 created in old version
- Setting Zone Types to Null in Security > Zones caused Zone Type (0) to be displayed. Not a real problem but has been fixed
- Zwave Responses show Error
- Velbus Comfigurator Response wizard commands have errors
- Update firmware for Controller always asks to Scan for Modules
- When a new file is opened and scan for modules discovers KT03, selecting KT03 will cause an exception
- Upgrading KT03 by direct connection to PC using the KT03 USB port has an error message that UCM version 6 is required.
