UCM mounting posts for EN01 enclosure
I\'ve recently had a second UCM added to my Comfort system and needed a new enclosure to hold it all as it didn\'t quite fit in the small one I had previously. I chose the EN01 enclosure as I think I read it had room for 3 UCMs - I\'ll likely add a Zwave3 when I can score one in the UK.
Unfortunately we discovered the EN01 didn\'t include any mounting posts for UCMs. There are just holes for bolting something to it from behind.
Is there a packet of suitable mounting bolts available? Here\'s what we used previously:
What do I need to mount some UCMs in the EN01 you can see in the background of the above image?
The UCM should come with a packet with mounting screws and standoffs which allow you to mount to the base of the EN01 or EN03
The EN01 doesn\'t have any mounting points like we\'re pointing at in the second picture above. Just holes so something could be screwed in from behind. When I received the 2nd UCM, which sparked the requirement for a larger enclosure than the one shown detached above, I do not recall receiving any mounting screws or standoffs with it unfortunately.
Any chance you could post a picture of the items you\'d normally include with a UCM? I can have a rummage to see if I have misplaced them, once I know what I\'m looking for, or query my supplier to see if they have any lying around.
Thanks.
4 plastic standoffs for the EN01 holes and 4 M3 screws for the mounting screw positions in EN03 are provided in the UCM package. See the picture
These are in the same plastic bag with the UCM
I\'m interested; whats the enclosure you are pointing at as assume it\'s not an EN01 or EN03.
Looks to accept just one UCM?
I\'d like to get one of these.
Couldn\'t be sure, Julian, I got it with my original Comfort install several years ago. You\'re right, it just fits one UCM and I have two now. It has mounting points on it already. If you look at the b/g of the first picture you can see the EN01 which doesn\'t feature similar mounting points.
So I definitely don\'t have a pack of those plastic mounts from my original UCM, but I\'ll see if I\'ve misplaced them from the new one. I don\'t recall seeing it though. In effect I need 8 of those plastic ones.
