PICED Download
Note
Use Piced 3.8.0 for KT01. Piced 4+ CANNOT be used for KT01
Direct download link is http://150.101.78.20/downloads/HomeGateF..._Setup.zip
In case that link does not work in future, here is another link
http://www.cytech-technology.com/temp/so..._Setup.zip
The Cbus Toolkit must be installed before PICED 3.8.0. Please download from http://www.cytech-technology.com/temp/so...1_Full.zip
Download the KT01 Manual here
Cytech Admin
Thanks Nigel
Note that the C-Bus Toolkit must be installed as well for PICED to work. Smile
Be advised that PICED 3.8.0 must be used in conjuction with Firmware 2.23.0 for the KT01. Earlier PICED versions may not support firmware 2.23.0.
Hi Adrian
Can you please describe how the firmware version on a KT01 may be identified.
Andy CHC
Hi Andy
The firmware version may be seen when you power the KT01. Alternatively, if you press the \"startup\" button on \"tools\" you should be able to see the version. Smile
Cheers
Please note that for KT01, the Piced software should be  3.80, 3.90, or 3.91
Pixced 4.0+ will not work with the KT01 firmware 2.23
