Vocabulary differs...
for as long as I can remember, every time I write PC-> Comfort, I get he message \"This configuration\'s vocabulary differs from that currently defined within Comfort. Do you wish to continue with the transfer?\"
Sys info: Comfort ll Ultra
Version: 5.183 (I would like to update this, but [Firmware upgrade] results in \"UCM does not support this operation\")
File sys: 34
Vocab no: 0
Custom vocab:0
System vocab Version:0
User vocab Version:0
LCD text version:0
LCD KP Minimum version:0
UCM Type: 10
UCM Version: 5.079
Comfigurator: V5.3.2.8
Language: English Residential
The problem should be  due to the UCM01 5.079. This UCM is about 7 years old and does not support the firmware upgrade or other features
The UCMs meant for Comfort II include UCM/232, UCM/USB and UCM/Ethernet, see the Cytech web site
https://www.cytech.biz/pc_interfaces.html
Your Comfort is Comfort II. If the voice can be heard on the keypad, then you can ignore the Vocabulary message.
If you are not making any big changes to your comfort then you may not need the new UCM
This system has been upgraded several times. As far as I can see, the UCM01 was used for the old RS232 interface, now unused as I have an Ethernet interface. Could I remove the UCM01 or might it be necessary for something else?
I would like to be able to upgrade the Comfort ll firmware, but Comfigurator [Firmware upgrade] results in \"UCM does not support this operation\".
Is it the old UCM01 that is preventing this?
If you use the UCM/Ethernet with firmware 5.178 or above you should be able to upgrade Comfort firmware and vicabulary
You cannnot do the same through UCM01
The presence of UCM01 should not affect anything as long as you are not using that Rs232 interface for upgrading
