Threads: 17
I have had another lightning storm (with no direct hits though).
My Ultra II gave a comms failure at first.
I reset the system, but then got \"wrong text press *1 together\" on both keypads.
I pressed *1 and then got \"no text data download aborted\"
There is no voice and no response on the keypads - not even the usual beep when I press a key.
Resetting and complete disconnect from power produce same result.
Please help.
Clinton
Threads: 17
Thanks for the quick response.
The lights flash correctly.
I can connect with the UCM/232 and get the system information.
I tried to do a Vocab Upgrade, but the Upgrading Vocab window stuck at 0% for a while and then I got \"Vocab upgrade encountered errors\" and \"The operation was cancelled\" messages.
I did also try to rewrite my configuration to Comfort and that seemed to work fine, but did not resolve any problems.
Regards,
Clinton.
Threads: 886
Can you upgrade the UCM and Comfort to the latest versions if you have not done so
Also before doing the Vocab upgrade power off Comfort and back on again
Threads: 17
Just to confirm, is my UCM a UCM05:
UCM PC01-066A
Serial Number: C000008
Thanks,
Clinton.
Threads: 17
Hi, I am not at the UCM at the moment, but I seem to remember that the RS232 port was mounted directly to the board - and not on a daughter board as in the picture?
Threads: 17
Thanks for the help.
Resetting the system, not pressing *1 on the keypads and connecting the rs485 cable directly to the main board allowed me to upgrade the vocab.
No firmware upgrades were necessary, although I do plan to do them now.
All seems fine now.
Clinton.
Threads: 17
I assume your comment \"If your UCM firmware is 5.100 and above it will support upgrading of other modules\" above is a mistake?
The manual says that 5.178 is required to do an upgrade (and that 5.100 is required for the UCM itself to be upgradeable).
Am I correct or can I do an upgrade with my UCM 5.156?
Thanks.
