[Sorry just noticed after posting that i think this should have been in a different section, but not sure if i can move it.]
Hi Guys,
Has anyone has experience of setting dim levels on X10 via comfort,
Iam trying to program my lounge lights to activate when in security off mode and the lounge sensor is activated, Lounge lights come on , and after 120 seconds dim to 50%, and there for when i get up again the lights go up to 100% again, etc...
So far i have got this, not sure if it is correct, infact there is something missing as it turns on no problem and dims after 120 seconds, but i cant get it to return to brightness when the sensor picks up again.
(Response: LoungeLUXDim)
If Input LightSensor <> 0 Then
AndInput Lounge
X10 M1 On
X10 DimLevel 0
X10 M2 On
X10 DimLevel 0
Do MLounge-Dim15 After 120 Seconds Using Timer11
End If
(Response: MLounge-Dim6)
X10 M1 Dim
X10 DimLevel 6
X10 M2 Dim
X10 DimLevel 6
If Input Lounge <> 0 Then
Do LoungeLUXDim
End If
The lounge zone is set to: on response = LoungeLUXDim
Thanks guys,
I may find this annoying if my PIR is too sensitive, if every time i lean back on the sofa the lights go up and down, but its worth a try i guess. I wont know if i donââ¬â¢t try.
Kevin
Hi Guys,
AndInput Lounge
X10 M1 On
X10 DimLevel 0
X10 M2 On
X10 DimLevel 0
End If
X10 M1 Dim
X10 DimLevel 6
X10 M2 Dim
X10 DimLevel 6
Do LoungeLUXDim
End If
Thanks guys,
Kevin
