Away mode disarm trigger alarm with no delay
My Away mode disarm trigger alarm with no delay.
I have configured zone response with action code 04,255 to start entry delay, still delay not seems to be not working, but trigger immediately.
very much apreciated for help. Have a nice day!
//ps
Opening the Entry Door zone when system is armed will start an entry delay
Hence the Main Door must be an Entry Door Zone Type (limne in the default template) and there is no need to have the Start Entry Delay action, as that is meant to start entry delay in other circumstances
If you still have problems  send your cclx file to support@cytech.biz so we can see what you have done
Thanks speedy reply.
Entry Door zone doesnt trigger the entry delay which used to be ok. that why i resorted to try using the response instead.
Entry Door zone is default setting except that i have changed the zone activation to triger 04 instaed of default 01 zone annoucement. That is the only thing i changed.
I am still using ENTRY version, Please advice.
thanks
Change the Entry zone type settings back to the original, and it should fix that problem. I dont know what you mean by triger 04 instead of 01. Zone types trigger alarm types, it has nothing to do with zone announcement
If you dont know the original setting, open a new template for Enrty and download again
Send your ccl file if you are still having problems
