KNX as Input modules
I have a project that using 10 units of RIO modules and we need over 9 Keypads plus touch screen, so we think of using KNX input push button modules and touch screen to be the main controlling units (through KNX bus c/w power supply & UCM/KNX2). so what is the possibilities of stable operation using KNX input modules and limitation of using.
thanks
KNX Inputs can activate Counter Responses to control anythinbg on Comfort. This is a well established method and works well, if that is what you need to do. I am not sure I understand your meaning though
ok, simply i have a system that consumed all Sem\'s & Lem\'s and 11 RIO so far that left me with 4 SCS only .
My Client request 10 SCS so i used KNX interface to install the 11 SCS
actually each SCS has 11 buttons, which it means 110 dedicated counter
is that right?
I dont know what you mean by using KNX Interface to install 10 SCS
Do you mean you use KNX switches in place of SCS?
what i meant is using UCM-KNX to interface comfort to the 11 KNX Busch-triton Switch
OK then you can assign the 110 counters to the group addresses provided you still have spare counters
