08-30-2006, 08:05 PM
[font=\"Times New Roman\"]Hi,[/font]
[font=\"Times New Roman\"]Iââ¬â¢m having problems getting my comfort II alarm and pabx to work together. Comfort is connected to the telephone provider at the Tel In and the Tel Out goes to my paxb, which sees the line as a normal external analogue line.[/font]
[font=\"Times New Roman\"] [/font]
[font=\"Times New Roman\"]My problem is with the polarity of the Tel Out. Set one way the local ringer and access from the local phones into comfort using the * key works, but the PABX gets upset picks up the external call on the first ring and proceeds to drop the call. (no good at all as I can't get any calls!) Set the other way the PABX is happy and external calls work fine but, the comfort ringer (doorbell) does not work and the local access does not work either. Iââ¬â¢ve tried swapping the polarity of the Tel In to no avail. I recall on my old comfort pro you had a tuning parameter to set the line polarity ââ¬â does UltraII have this?[/font]
[font=\"Times New Roman\"]Thanks in advance for your help[/font]
[font=\"Times New Roman\"]Mark[/font]
