Wrong Counter Values
I\'m using the latest posted Comfort Ultra Beta firmware.
I\'ve had a problem with my ZWave lights for a while, getting spurious lockups, as described in another thread.
Montoring the comfort bus I\'m now noticing spurious counter values.
Only reason I have spotetd is because i\'m using my Comfort Client with sounds on for the lights so I hear the lights switch state.
An example,  all my zwaves are straight switches (no dimmer versions) as I use CFL\'s;  so I expect to send \"00\" for off and \"FF\" for on.
Just got a counter report from Comfort that went like this when the light is already ON (ie CT32FF)
CT32FA  <- What\'s this!!
CT32FF
Another example
CT3501 <- What\'s this!!
These arent valid on/off counter responses. CTxxFF and CTxx00 are the only valid responses I should be getting.
Any ideas.  Are the counters right and it\'s the logic on the UCM/Zwave that\'s causing.  Dont know how to get to the bottom of this.
Can you send me the Comfort Bus monitor log, via PM,  for analysis?
Thank you.
Best regards,
Leon
