CWM - HTML Applet Designer
Correct me if i\'m wrong.
Is that HTML Applet Designer unable to read .CCLX file format? Only support .CCL & .CCT format?
My HTML Applet Designer software V1.0.4[5-12-2006]
Thank you
Correct, you have to use ccl file for CWM Designer
You can use Comfigurator 3 andc save as ccl
In future we will allow CWM Designer to read cclx files
During try to save the file from CCLX to CCL format by using Comfigurator v3.0.1, below is the error msg encounter :
System.NullReferenceException: Object reference not set to an instance of an object.
   at Comfort.AlarmType.ToCCL()
   at Comfort.Configuration.ToCCL()
   at Comfort.Form1.SaveAs()
   at Comfort.Form1.saveAsToolStripMenuItem_Click(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Not sure what is the error msg mean?
Thank you.
Please attach or send us the cclx file.
The problem with cclx to ccl conversion will be fixed in the next version on Comfigurator 3
4 Guest(s)
