Response Wizard
Hi Chiu
I\'m changing the client to provide filtered lists of Responsesand filtering on ActionSource values that contain certain keywords.
I already know:
X10
Zwave
CBUS
Smartfit
ie
<string>X10 B0 AllLightsOff</string>
<string>Zwave BasicCommand 3 1 0</string>
<string>Smartfit QueryHWDemand 2</string>
<string>CBUS On 2 216  ! Switch Pantry Light ON</string>
But can you let me know what other ones you may have as these dont generally appear unless you have the UCM fitted so cant tell.   Thinking RAKO etc
I\'ll then add support for them in the Comfort Client
The list of UCMs supported can be seen in the dropdown list when you click on the UCM Type in the Properties window below ID and Name
Once you add the UCM type (and you dont need to have the UCM physiaclly present) you can see the Responses for that UCM in Response Wizard under the UCM tab
Thanks,  I\'m suitably embarrassed for not realising this!!:?
