Comfigurator 3.0.0 is ready at last. Please download from Comfigurator 3 Link
Comfigurator 3 replaces Comfigurator 2. The new software is based on the .NET platform, and represents a major improvement to the user interface and functionality.
Both Comfigurator 2 and 3 can coexist in the same PC. Conversion between Comfigurator 2 and 3 is possible. The Icon for Comfigurator 3 is shown in the image below with a \"3\"
Please feedback and post any bugs found in this forum
A training slide on Comfigurator 3 programming is available for download from our website
Some of the new features include
- New User Interface with 3 pane view allowing easier editing.
- cclx file and cctx template formats to replace ccl and cct files
- Auto Save interval
- Selection of Toolbar items
- Monitor I/O in View options instead of seperate pop-up window
- Support for new UCM/USB. Connection settings include Serial, USB, Network
- Modules Tab for UCMs. Supports Scanning of UCM Types and firmware version info
- Supports new UCMs; Zwave, HDL Configurator in Modules Tab. UCM is no longer in Names
- IR Transmit Codes which are used are saved in the cclx file
- Zones can be dragged and dropped, and copy/paste operation is supported
- Configuration Flags for \"Detect Battery Disconnect\" and \"Require Engineer Code to write\"
- In Sunrise/Sunset Times, the city is saved in the cclx file
- Response Wizard - IF x AND y, IF x OR Y conditions
- Response Wizard - Actions can be moved up/down in a Response
- Response Wizard - Description will auto-generate the Name so there is no need to enter the Response name
- Response Wizard - supports comments for each action
- Prevent writing wrong or mismatched file system to Comfort which would cause red/green leds to turn on and system not to operate
- Import Configuration screens (Tuning Parameter, Voice Settings, etc from other files
- Sorting order of Responses (Name, Number) is saved for each file
- Conversion of ccl files to cclx with Accented Characters in Response Descriptions cause Exceptions. Accented non-ASCII characters are handled correctly when entered as comments in Comfigurator 3
- Scan for UCMs gives the number of UCMs found rather than the number of the last UCM, eg UCM 1 may be missing, so if there are UCMs 2 to 6, Number of UCMs will be set to 5
- In Alarm Types, the checkboxes for phones 5 and 6 turn on and off together when Phone 5 is selected
- For Z-Wave configurator, Reset To Default may result in invalid data read from the EEPROM
- Selective Write in some circumstances gives an Exception Error
- UCM01 < 5.092 unable to write and read to Comfort
- Default template for Comfort II Ultra has all Siren Settings for BELL to OFF. This is not a Comfigurator bug, it is a wrong setting of the template. Please correct on the cclx file. Conversion from ccl files does not have this problem. Please replace the def34.cctx file with the one attached in the next post
- Pager ID Code leading zeroes are removed eg \"0123\" becomes \"123\"
- Counters assigned in Zwave and HDL UCMs are not shown as referenced in blue in Events > Counters
- Changes in Control Menu may not be auto-selected in Selective Write
- When the U4 eeprom contains the wrong file system, Comfigurator does not write the correct file system into the EEPROM. For example, if the U4 was previously wriiten with a different file system or if it is blank, Comfigurator 3 is not able to write the correct file system data into it. Hence Comfort will start with red and green leds on indicating mismatched file system. Use Comfigurator 2 to correct this by writing the correct file system.
- Action 31 (Get Last UCM Counter) entered as Action Code is removed by Comfigurator. Get Last UCM Counter can be entered by Response Wizard
- If two responses have the same name except for a difference in Capitalisation, eg Responses named ABCDEFG and ABCefg, then when an event selects one of these Responses, the incorrect one may be selected, as Comfigurator should not allow the same Response name with different capitalisation.
- When a response referenced by a Event has its Description changed and then the Response name is changed using Autogenerate Name, the Event still point to the the old Response name. The renamed Response is not referenced, ie does not appear in blue
