07-08-2008, 06:01 PM
(This post was last modified: 07-08-2008, 06:30 PM by delbrookdad.)
I am having a problem with a new UCM05eth. It is connected to a new Gen II main PCB. Config is as follows:
PC and UCM are connected to 2 ethernet ports on ADSL router. PC has Internet connectivity via the router. I can Buzz UCM from DS Manager. I can ping UCM from PC.
D1 and D102 LEDs on all the time, D103 blinks twice every few seconds.
SW8 has A,B and F inserted, H can be in or out (with appropriate setting of RTSCTS Flow control DS Manager) Makes no difference.
J2 set to 485
JP2 connected to Main PCB (RS485 connector)
D10 LED is on all the time regardless of whether Comfigurator is running or not.
Firewall is disabled or if it is not ports 1001 and 65535 are opened and Comfigurator and Wizcomfort are in the exceptions list.
D103 LED lights up after Comfigurator requests User sign-in. But error message \"No response from UCM\" is displayed.
IP Address of PC is 192.168.1.2 Subnet mask is 255.255.255.0 and Default Gateway is 192.168.1.254.
ADSL router has the following settings. Local Network IP Address is 192.168.1.254. IP address is 86.45.3.108 IP gateway IP address is 159.134.155.6
UCM IP address is 192.168.1.2 Gateway IP address can be set to that of PC, router, Default Gateway or IP gateway addresses but still the same problem.
Have tried Hyperterminal configured for IP and get no response and from Wiz comfort I get a \"no reponse from controller from |||CMD LI6789|\".
HELP, Thanks Andrew
J2 set to 485
HELP, Thanks Andrew
