local line
The installation i\'m working on has a dect handset, it does\'nt ring when the door station is pressed or when you just want to ring into the landline, aswell as i can\'t access the comfort system through the dect phone by pressing *,  the comfort system does not have a ringer module fitted in j57, does this not work due to the missing module? There is a gsm module though,
 thanks neil
You need to have a RGR04 module in order to ring the hones, but it looks like you may not have set the number of Door Stations to 1 in Comfigurator (Reset required)
Without the Ringer, the Keypad should chime (\"ding dong\") and when you press anny key, it should say Press 0 for Door station
Also check that the ID shunts are inserted (ie ID=1)
Thought so, the door station works on the phone after pressing the button it just does\'nt ring the phone,
 thanks for the speedy answer, i\'ll get on to my client to buy the ringer board.
 thanks neil
