New Keypad Design Poll - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: KP06/KP06A/KP04A Keypads (https://www.comfortforums.com/forum-105.html) +--- Thread: New Keypad Design Poll (/thread-2254.html) |
- securiscan - 05-09-2011 Sorry, but our back boxes in Australia are a lot smaller. There would be more options to install the codepad on a wall if the design was slender and upright. If a person uses their left or right hand on the numerical codepad, they could easily view the LCD display if it was located above. - ident - 05-09-2011 [user=82]securiscan[/user] wrote: Quote:Sorry, but our back boxes in Australia are a lot smaller.I dont realise you were from Australia Yes it would not fit your backboxes. It is already quite tight in the box and a lot of engineering was done to make it fit the uropean boxes so the current design would not go into your boxes However we are supplying the EU backboxes so that may still be an option. It should not look odd. - ident - 05-09-2011 [user=151]keiba_solutions[/user] wrote: Quote:Why make a frame at all? If it is being designed to fit into standard 55mm type frames the emphasis should be on making the actual KP06 unit itself styled to suit.We do need to supply a frame as not all customers are able to get KNX frames easily. KNX is not popular everywhere yet But you have a point about looking good with different manufacturers frames. The 2 modules are quite neutral and should fit into a variety of manufacturers frames. We may take photos with different frames - petar555 - 05-09-2011 Please send me the price list of your product ! - rodime - 05-09-2011 Design B with the bigger numbers of A. And availability in Black or white would be good. IR is important - paulgwatkin2 - 05-09-2011 Having a security system keypad that looks good asthetically is important - especially given the fact the Comfort is by it\'s nature a high end product. The type of customer chosing a residential install of Comfort are going to want this to fit with the decor and other systems like CBUS etc. Ideally multiple faceplates should be supported, black, white etc but also looking to try and mirror faceplates like those used by the Saturn CBUS range from Clipsal. Voice station (left module) from C as is has the clearest indicators and vol control Keypad from A as it has the cleanest look Surround from B as it is simple and has IR. Paul - ident - 05-10-2011 [user=4181]petar555[/user] wrote: Quote:Please send me the price list of your product !The list of Comfort distributors is at https://www.cytech.biz/dealers.php We do not have any distributors in Serbia. If you weant to buy Comfort you can order from any nearby country or contact us direct at sales@cytech.biz - ident - 05-10-2011 The KP06 can be mounted in Horizontal and Vertical Orientation An impression of the KP06 mounted vertically is shown ![]() - palmlodge - 05-10-2011 Can you disable the very annoying key beeps ? - juwi_uk - 05-10-2011 \"Design A\" picture seems to have the IR receiver on it but \"Design B\" doesn\'t . The explanation suggests it\'s the other way around? Bit confused. :? Julian |
