Hello to all Comfort customers, and installers
We are in the final stages of designing a new LCD Keypad model KP06, in the same family as the KT03.
This keypad is designed to be flush-mounted into a standard European 2 gang backbox. It will look similar to a KNX switch with a System 55 2-gang frame (ie 55 x 55 mm central cutouts). This means that any System 55 2-gang frame fromn any KNX manufacturer (eg Gira, Jung, Merten etc) can be used in place of the frame that comes with the KP06.
The KP06 can be mounted horizontally or vertically, as with the KT03
Volume control Up/down buttons instead of the thumbwheel on the KP04
We would like our customers feedback on several allternate designs of the frame before we start the production tooling.
[color=\"#aa0000\"]Pleave VOTE by clicking the VOTE button above[/color]
These alternate designs are shown. Note that the choice is between the different Frames only. Even though the keypad and LCD modules may look different, the final version of these have been determined
Design A
Design B
Design C
The ones in black will have IR receivers to allow RC01 and unitversal remote controls to control Comfort
The Design A will not be able to receive IR signals, nor will third party frames
There is a poll to indicate your choice. Please participate by clicking on the VOTE button
However we cannot guarantee that the most popular design will be selected because there may be other factors to consider.
A photo of the actual Keypad module is shown
This is an impression of the KP06 in Vertical Orientation
If you do not find the KP06 frames to your liking, frames from KNX manufacturers like Jung, Gira, Merten etc can also be used, for example some of Gira\'s Esprit range are shown (available in glass, Chrome, Aluminium etc)
Design A
Design B
Design C
