Comfort on the Network - Printable Version
+--- Thread: Comfort on the Network (/thread-3653.html)
Pages: 1 2 3 4
- Vangelis - 02-19-2015
Hmm strange - So are you now saying that to login with Clear Terminal you use /031234 (without the LI as opposed to /03LI1234)
What Win platform are you using?? (just want to discount it being a WinXP thing.
Another thing I have found out is that OSX uses Unicode (2byte), so as the iOS Comfort App works, am I correct in assuming that when logging in, the App uses the same format as above??
I just want to rule out differences between Windows and OSX
Thank you for the support so far Smile
Vangelis
- slychiu - 02-19-2015
No, the command to log in is LI1234
You cannot type /03LI1234
The /03 is sent by the Hotkey
There is other options in Clear Terminal
Go to Tools > Send ASCII/BINARY and select Binary
Then click 03
Type LI1234 in the text box
Also go to View ? Select Display Mode and select Mixed to see the binary characters
Thanks Slychiu
So what\'s the difference between pressing the HotKey to send /03 followed by me typing LI1234 and just typing /03LI1234 (without pressing the Hotkey) ?? Or am I confused?
Vangelis
In the 1st case the hotkey sends the hexadecimal character 03
In the 2nd case it is sending the ascii characters /03LI1234 which is not correct
Ahh - Got you now. I will try this out again when in front of my system.
Thanks..
Vangelis
btw does the iPhone app send the text to Comfort in this way??
ie Hex 03 and Dec LI1234
Vangelis
Yes, the same way
- HenleyBranch - 03-08-2015
OK, Vangelis, just to share your pain, apologies for my absence. Please do not think I have been enjoying Comfort Indigo connectivity nirvana, I just struggle to fit trouble-shooting this issue around the day job! Thanks Chiu, Ident, for the tips.
I \'nearly\' have this working. I manage to make a \'read-only\' connection to Comfort which allows Indigo to listen to the codes and react to them. This works really well as it allows things like the IP control of a Denon amp (welcome home with playlist - potentially by user), CCTV (when outside sensors detect motion - message a snapshot of cameras to iPhones), connectivity to Netatmo, sending iOS notifications of Comfort events etc. etc. When it works it is great.
However, how I am making this connection is not quite right, and it may persist for a day, or a week, or even several weeks, but then it drops and won\'t restart without a precise sequence of events. This has puzzled me for months.
I think this is because whilst I am able to get Indigo to make a persistent secure connection to Comfort, I am unable to get Indigo to send text in the correct format to Comfort. I think it is to do with this /03 character.
Initially I thought I had it all licked, but I have realised, I think it has been my sequence using ClearConnect which just happens to work, but which I have been unable to figure out how to solve a sustained connection, using Indigo. I\'ll explain my current connection sequence.
Using Indigo http://www.indigodomo.com on the Mac, I have used the Network plugin to create a connection to Indigo. This connects, persists, and actually locks out other connections such as Configurator.
Initially, I thought that LI1234 /03 was the correct sequence, following earlier comments in this thread last year with Ident.
However what I have realised, I think, is that I am not successfully managing to get the Indigo Network plug in to send any text which Comfort is recognising. What is actually happening is that I have been logging in with Clear Connex and then using that connection in to Indigo. I’ll explain.
If I establish the connection using the Network plugin http://www.cynic.org/indigo/plugins/online/network.html, I am unable to get any response from Comfort or even log in whatever combination of /03LI1234 or /LI 1234 or 1234 /LI.
If, however, I disconnect indigo from Comfort, then form a connection with Clear Connex as described in Chui’s post above, then close that connection in Clear Connex without logging out, then re-enable the connection in Indigo to Comfort, suddenly Indigo is listening to all the TCP traffic and can respond in the ways I describe above.
I think this is what I have been doing as it explains why I have had such an ‘unreliable’ connection since first trying this a year ago. The connection fails, I go back through, test in Clear Connex, and then find it actually works again, but it may actually be Clear Connex establishing the connection, not the Indigo network plug in.
I have established a TCP connection between Indigo and Comfort.
I have got Indigo listening to TCP traffic (albeit inadvertently using the method I describe above).
I have not got Indigo to be able to send to Comfort.
I appreciate this is not to do with Comfort directly, and is a pretty niche issue, but any assistance in getting this last step working would be great for myself, Vangelis and anyone else thinking of connecting Comfort to a Mac home server.
- HenleyBranch - 03-09-2015
SOLVED!
Having looked into this today, discovered the answer is \\x03 preceding each command! Ensure Carriage Return is the line format.
It was actually answered on a post I made some time ago on the Indigo forums that I hadn\'t seen...
http://forums.indigodomo.com/viewtopic.php?f=25&t=11273
So to send the login command, it is \\x03LIxxxx, where xxxx is your Comfort user code.
Other commands also return two-way communication via TCP. All good.
- Vangelis - 03-09-2015
Hey HB - Weirdly I went through the same thing you did before I got it solved.
I would telnet to Comfort on my Win7 machine and issue Ctrl-C with LI1234 and it would login, then I would close this connection and have Indigo connect to Comfort via Network Plugin and it would see output (but with x03 prefixes). This put me on track for solving the issue (as you did)
So I now have an action that executes the Device Network Plugin with Comforts IP and waits for \'Connect to be True\'. I then issue x03LI1234 to login
I check for a Disconnect (as Comfort will time out the connection eventually) and then auto-connect. This can be solved by changing the value in DS Client on Comfort (so connection doesn\'t time out - just not got round to it yet)
Vangelis
