Comfort on the Network
I have two home control systems running, one based on Comfort for security and security-related X10 control of lights, and another based on Perceptive Automation Indigo running on a Mac server as part of our home network of Macs, controlling iTunes library, multi-device iOS control of X10 lights, scene setting etc. Both very reliable independently.
My project for the next 12 month is to integrate them better. Currently I have some X10 connectivity between them, for example, an alarm in Comfort generates a alert email and iMessage using Applescript on Indigo, using an X10 on command as a trigger. This has proven less reliable than using X10 for lighting control for some reason, but was the only way a novice like myself could initially find to do this.
Both systems are sitting on the wired ethernet network of the house, so there must be a better way. I am aware for example, using Comfigurator, that flags are reported live to Comfigurator by Comfort, so Comfort must be \'broadcasting\' the status of those flags over TCP/IP.
I therefore want to get Indigo to listen in. I have a plug in for Indigo, which does exactly that http://www.cynic.org/indigo/plugins/online/network.html but I am outside my comfort (no pun) zone here and am not sure what protocol information I would need to get this to work.
Has anyone any experience of making this kind of \'listening\' to Comfort\'s TCP/IP traffic work?
Any tips, gratefully received.
Henley
You can download the comfort serial protocol from https://www.cytech.biz/serial_interface_...gory_id=99
This wil show what commands you need to use to send commands and receive replies and reports from Comfort via TCP
Thanks ident, very helpful.
Please excuse my ignorance, but does Comfort by default \'broadcast\' events such as alarms via TCP to devices \'listening\' on the network?
Henley
You will of course need a UNIVERSAL UCM with Eth03
Quote:Please excuse my ignorance, but does Comfort by default \'broadcast\' events such as alarms via TCP to devices \'listening\' on the network?
No, Comfort will not broadcast TCP
Your device must connect to UCM/ETH on the IP address and Port which is configured in DS Manager (for eth02) or )CS manager for ETH03)
This allows the device to \"listen\" to the messages sent by Comfort when a zone goes open and closed, alarm happen etc as descrbed in the Serial Protocol
Quote:You will of course need a UNIVERSAL UCM with Eth03
If the device is meant to communicate using the Comfort protocol, then you must use the UCM/ETHxx.
A Universal UCM must be used when  3rd party device communicates with Comfort using the devices protocol.  The universal UCM can be programmed to send any message or string to another device
In your case, which seems to be software -based, the UCM/Eth03 seems to be more suitable since you should be able to program it to understand the comfort ptotocol
Thanks Ident.
I am using UCM/ETH02 (I think - is there a way of telling without opening up the panel?)
Have followed instructions in serial protocol, and although I have established a connection on the correct IP and Port to Comfort I am struggling to get the responses from the UCM outlined in the protocol.
Hyperterminal mentioned is not part of Windows7. I am using ClearConnex ClearTerminal. I have set it up as per the instructions in the protocol but as a TCP connection. Do you have a recommended terminal product I should be using to test the connection / responses, and can you refer me to appropriate setup instructions?
I have downloaded ClearConnex to try itinary
In Connections, start a new connnection with the IP address and port of the UCM/ETH. For this purpose it does not matter whether you use ETH01 or ETH02
After connection you need to log in by sending the binary character 03 (which is the start of line character) followed by LI1234 assuming 1234 is your user code and return
The trick is in sending binary 03
You can define a Hotkey as I have done
/03 assign to F2 hotkey
Press the F2  key followed by LI1234 and Enter
This logs you in and you will see LU01
[img]data:image/png;base64,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[/img]
Now you can enter the commands in the serial protocol
eg
I?01 means Get Input 1 state
the reply is I?0100 means Input 1 is off
Remember to enter F2 before each line
Thanks Ident. That worked!
Except I am not getting responses on separate lines. They are overtyping.
Presume something in settings.
Just a note to add, thanks so much for your help Ident.
Took me a while to work out no space between /03 and LI1234
I finally have Comfort talking to Indigo over Ethernet!
Brilliant! Endless notification, Applescript, iTunes, CCTV possibilities now...
Henley
Hi Henley,
Following this thread with interest! Am planning to go down the Indigo route in the New Year (already have Comfort2).
Guess you can now use the Comfort sensor status (via the Indigo Plug-In) for the Indigo UI on say a tablet?
Probably want to pick your brains on some of your setup if that\'s ok?
Vangelis
5 Guest(s)
