Ucm/Ethernet - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: Ethernet UCM/ETH03 (https://www.comfortforums.com/forum-113.html) +---- Forum: UCM/ETH01 & UCM/ETH02 (https://www.comfortforums.com/forum-119.html) +----- Thread: Ucm/Ethernet (/thread-761.html) Pages:
1
- Guest - 08-22-2007 Are you trying to reset the Ethernet plug-in? I\'m afraid I do not think it is possible unless you are able to connect to it, which now you are unable to do. - slychiu - 08-22-2007 There may be more than 1 firewall on the machine, eg Windows Firewall? Is it possible to try it on another network? - dcrera - 08-22-2007 Hi, Yes, I did on 3 networks. I am giving up on this and sending the unit back to my distributor for evaluation. Thanks - slychiu - 07-25-2008 Please note that the old UCM01 cannot be used with the ETH01 Plug-in as the J2 shunt is hard soldered to the RS232 position. We have had several instances where a former dealer sold an old UCM01 with a new ETH01 which was not able to work. However UCM01/Ethernet shipped from the factory has the correct connections soldered in so can be used for this purpose |
