Version 2.2.0 Login - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 2.X (https://www.comfortforums.com/forum-67.html) +---- Thread: Version 2.2.0 Login (/thread-698.html) Pages:
1
- garym999 - 08-08-2007 Also remember that the pressing of F,0 may also need authorisation depending upon how the keypad options have been programmed. So if your system says \"please sign in\" after pressing F,0 then you will need to enter the user code to confirm the action. Entering the engineer code will just result in a sign-in error beep. To check your programming in Comfigurator go to \"Control, Keypad\" and look at the \"key 0\" line. It you have a tick in \"need code\" then you will need to authorise F0 with a user code. |
