IRIO - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: IRIO (https://www.comfortforums.com/forum-129.html) +--- Thread: IRIO (/thread-4328.html) |
- slychiu - 10-25-2015 Each IRIO can have 2 submodules, each submodule has 4 outputs so max 8 outputs on IRIOMax of 15 IRIOs in the system - Guest - 10-25-2015 how about inputs ? can be 8 inputs combination with 8 output ? the sub module can be a combination type ? ( eg : tws and IR ) ? - slychiu - 10-26-2015 The number of inputs for submodules depends on the type of submoduleThe table in the first post tels the numbers of outputs or inputsThe individual manuals for the submodules gives all he detauils - cc_uk - 03-23-2016 Hi Is the IRIO shipping yet? I checked in the UK and don\'t seem to see it listed for sale from one of the distributors. - slychiu - 04-19-2016 Yes IRIO and mist submodules are available, except for 2 submodules, the TWS for lighting and Blinds You can try to order them frm your distributor, although they may not have it in stock yet - bahrami - 07-01-2016 it is very useful if there was 6A or 10A relays on submodules boards. in this case we can use it directly for active or deactivate electrical loads. - slychiu - 07-01-2016 The ISM06 and ISM07 submodules have 10A rated relays - Ingo - 07-01-2016 ISM06 only. The ISM07 is ELV rated, 1A or less depending on the voltage being switched. - slychiu - 07-01-2016 oops that\'s right
- John W - 07-12-2016 Is it possible to use these with a comfort 1 main panel ? My panel is still going strong but I want to replace switching of some lighting circuits that is currently done by x10, and this would be cheaper than velbus etc.Also are there any other UK dealers other than lazer, as they don\'t show any stock. |
