The IRIO01 (or Intelligent Remote Input/Output Module) is a multi-purpose automation module with 8 inputs and 8 outputs. An IRIO has the flexibility to configured for a variety of automation functions by plugging in a selection of submodules into 2 slots. Up to 15 IRIOs can be installed in a Comfort System.
The Manual for IRIO and submodules can be downloaded from https://www.cytech.biz/intelligent_remot...odule.html
Plrease visit the IRIO website at https://www.cytech.biz/brochure/irio.html
IRIO without Submodules
IRIO with 2 submodules
What does the IRIO do?
The IRIO handles the automation functions in Comfort in way that is easier to program and reduces wiring. Instead of programming Responses and actions, Functions are selected, and mapped to Comfort registers like Flags, Counters and Sensors. For example, the Heating or Cooling function works by assigning the setpoint to a Counter and temperature to a Sensor Register. Putting a value into a Counter changes the setpoint, and comparing the temperature in the sensor register allows the IRIO to decide whether to turn on the heating/cooling relay.
The function is mapped to a Comfort Flag, so that setting the flag will enable the function and clearing the flag disables it. The temperature can be obtained by the ISM01 or ISM07 with temperature sensor or other means, eg via KNX, Cbus or the TSM01 Temperature Sensor Module
For example, the ISM04 TWS subModule for control of lighting two way switches reduces wiring as it is not necessary to connect Inputs and outputs to Comfort. This submodule allows the current threshold t be adjusted so that it is able to handle all different lighting loads including very low current LED lighting down to 1 watt.
The ISM05 Blinds submodule controls a Blinds motor without needing a separate Blinds controller. It is able to move the blinds up and down as well as position the blinds anywhere with the help of a built-in current sensor.
Submodules
Each IRIO can accept two submodules from the list below;
The IRIO baseboard comes with 2 programmable analog outputs (0-10V) for dimming and control which are available without any submodule.
Functions
Each Submodule supports pre-defined Output and Input functions
Output functions include;
Input functions include;
Each submodule can only select the appropriate Output and Input function that is applicable for the hardware. Only the applicable functions for each submodule can be selected by Comfigurator.
The UCM/Logic can be used as a Controller for IRIOs where an alarm system is not needed. The UCM/Logic has no alarm functions and has no Inputs or Outputs but has all the logic programming capabilities of Comfort as well as a plug in Ethernet interface (ETH03) or USB interface for programming and access by the Comfort apps
http://www.comfortforums.com/forum117/4459.html
Submodules
- ISM01 Digital I/O submodule (4 Digital outputs, 4 digital Inputs)
- ISM02 Digital Outputs/Analog Inputs submodule *(4 digital Outputs, 4 Analog Inputs)
- ISM03 IR submodule with current sensor Inputs (4 IR Outputs, 4 Current Sensor Inputs)
- ISM04 Two Way Switch (2 Two way switch Controls) - Not available yet
- ISM05 Blinds submodule (2 Blinds Controls) - Not available yet
- ISM06 NO/NC relay submodule (4 Relays with NO/NC)
- ISM07 Relay I/O submodule (4 Relays, 4 digital Inputs)
Functions
- On/Off
- Heating/Cooling
- 2 way/3 way HVAC fan
- Air-con Interface by relays
- IR signal
- IR with Feedback
- TWS (Two way switch)
- Blinds
- Analog Output
- Digital
- Pulse count
- Current sensing
- Temperature Sensor
- Resistive Sensor
- Analog Input 0-10V
