Android Tablet App Beta 1.82/ 1.83 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort Android App (https://www.comfortforums.com/forum-110.html) +---- Forum: Android Apps - 1st generation (https://www.comfortforums.com/forum-121.html) +---- Thread: Android Tablet App Beta 1.82/ 1.83 (/thread-2973.html) |
- admin - 07-24-2012 can you confirm again that 1.8 still installs ok? - Ingo - 07-24-2012 Yes, 1.8 installs fine. Just a note: When I login, and the system is already armed, I don\'t get an indication that it\'s armed. I use two UCM/Ethernet\'s, one for ComfortClient and the other for Remote access. Ok, this is odd. I installed 1.8 again, then uploaded my modified cclx file and reinstalled 1.8.2 and it seems to work. The above issue seems to be resolved using 1.8.2. Perhaps something was left behind in the initial \'Uninstall\' of 1.8 that 1.8.2 didn\'t like. - Ingo - 07-24-2012 Before I forget... The application sounds, like Countdown and Arming, on my HTC Desire seems to be extremely loud. Can it be made to follow Media or Ringer volume? Ingo - ident - 07-25-2012 [user=4252]Tan121[/user] wrote: Quote:To ident: Last version did not work with 2.3We have checked that unused zones (Zone Type 0) are not shown in the app 1.82 If you use only 7 zones, and the other zones are Zone Type 0 (Null) then they should not be appearing in the zones list - Ingo - 07-25-2012 I also see zones even though they are Null. That said, I don\'t see zones 65-96. Here are the difference between Zone 64 and Zone 65. Perhaps ZoneTypeName is not as \'Null\' as it should be. Quote:<Zone Number=\"64\" Name=\"Zone64\" ZoneTypeName=\" \" ZoneWord1=\"Bypass\" EntryPath=\"false\" Restore=\"false\" Partition=\"0\" VirtualInput=\"false\" Announce=\"false\" /> Quote:<Zone Number=\"65\" Name=\"Zone65\" ZoneTypeName=\"\" EntryPath=\"false\" Restore=\"false\" Partition=\"0\" VirtualInput=\"false\" Announce=\"false\" /> - ident - 07-25-2012 What zones can you see which are Nulll Zone Types? The zone type name for Null is \"\" - Ingo - 07-25-2012 I can see all 64 zones, even the ones setup as \'Null\'. Zone 65-96 has not been modified since they were added by Comfigurator, I suspect Comfigurator has an issue where it inserts a :SPACE: instead of a :NULL: - Ingo - 07-25-2012 I just confirmed, as soon as I edit Zone Type to something else and set it back to \'Null\' then it inserts a :SPACE: character. - ident - 07-25-2012 Can you send your cclx file to support@cytech.biz so that we can check the problem as e do not see this with our own testiing - ident - 07-25-2012 OK let us test this. Dont need to sendyur cclx file for now |
