Android Tablet App Beta 1.82/ 1.83
The new version of the Android app is ready for testing, in the attached apk file
Send this into your mobile device and click to install. It will replace the  previous version but will not delete any data
The changes are
  1. Fixed an issue where the Security Mode status was not updated after logging in when the system is large
  2. App will log out and go back to the login page when screen times out or another app is active or the standby button is pressed.
  3. Fixed problem where if wifi is out of range there was no indication. Now it will log out.
  4. Fixed a number of bugs
Known Issues
  1. Cameras do not work
  2. back key still has problems
  3. after wrong code is entered, correct code does not work for about 20 seconds
[color=\"#0000ff\"]The apk file and quick start instructions can be downloaded from https://www.cytech.biz/product_details.php?item_id=373[/color]
Cool :-)
Are we looking at android phone app soon ?
That will be the next after we get this out
The app (last version) did not work with HTC Desire Android 2.3, but With HTC ONE Android 4.0 it works fine. And if you have a bit bigger screen then it absolutely enough to use the tablet app.
One sugestion: Zone open and closed images are misleading. If the zone is closed you see red cross. Red cross is like an error. But if the zones are closed, then everything is ok. So maybe you think about the icons and change them. Closed zone should not be red but green in my opinion.
One more thing. I see zones that I am not using. Is it possible to hide not used zones?
You mean that 1.82 did not work on Android 2.3?
Do you mean that it did not install? What error message did you see?
We will consider  colours
We have tested 1.8.2 on Samsung Galaxy S2 phone with Android 2.3.3. It worked OK
What is the minimum space required for the installation? My phone doesn\'t have enough. Can the App not be installed on the SD card?
Ingo
To ident: Last version did not work with 2.3
That version I have not tried.
Also still question about hiding unused zones. Would it be possible to hide unused zones, i see 64 (something like that) zones, but i am using only 7 zones.
The unused zones should not be shown
That is a bug which is now listed in the \"Known Issues\" List and will be fixed in the next version
I finally installed 1.82 on Android 2.3.3 (HTC Desire) and I get a \'Force Close\' message when I press the Key button. 1.80 worked fine.
Another issue is that I lost my file asociation to the config file. When I click on it it doesn\'t seem to be associated to the Comfort App. Reinstalling doesn\'t help.
Ingo
21 Guest(s)
