Bypassing a zone - Printable Version
+--- Thread: Bypassing a zone (/thread-1962.html)
Pages: 1 2 3 4
- emabonacchi - 08-19-2010
Can you please take a look at the \'bypass by L16\' command in the file i have sent to you?
How can i use it?
I have tried to send \'L16ON\' before arming the system and after arming the system, but in both cases, the zone was not bypassed because i have tryed to open the window and the alarm turned on.
..........just solved the \'voice-mic\' problem......
The problem was that i am really an idiot...... cabling error. Two wire was \'green\'. One dark-green and the other light-green.....
Now when i press \'F-1\', a voice ask me to signin, i signin and then i am able to bypass the zone!
So,everything works as espected.
I can tell the problem is NOT solved, because there was NO problem.
The only problem was me.... and i am very very sorry about.
Now, i would like to \'bypass\' the zone from central CPU.
Can someone suggest me how to make an X10 signal (L16ON in my configuration) works?
Thank you.
- hendy - 08-20-2010
In your configuration file, you have created the \'L16ON\' response but you have not placed it in the correct event i.e. in Events > X10 Receive Codes > L16 On Response.
Another thing, I notice that you are still using the old Comfigurator 2 software to create your configuration file.
Please use the new Comfigurator 3 software as this provides new features and bugs\' fixes that Comfigurator 2 does not have.
- emabonacchi - 08-20-2010
Well, this was another stupid error from me.
I have put \'L16ON\' response in X10 event \'A16ON\' response.
Now, everything works.
I am trying to do a thing, but i am not able, so i would like to receive some sugestion:
I would like to set 3 zone L16, L15, L14.
When x10 device L16 is \'on\' and i arm the system in night mode, i would like Cp9000 bypass zone11 (called \'Cameramat\' in my configuration file), then arm in night mode.
When x10 device L15 is \'on\' and i arm the system in night mode, i would like Cp9000 bypass zone14 (called \'Cameretta1\' in my configuration file), then arm in night mode.
When x10 device L14 is \'on\' and i arm the system in night mode, i would like Cp9000 bypass zone10 (called \'Camereta2\' in my configuration file), then arm in night mode.
If these x10 devices are \'off\', i would like Cp9000 arm the system without bypassing these zones.
I am reading the Help file and the forum, but i have not found a possible way to do it.
What is a \'flag\'? Is it pheraps a \'variable\' i can configure as i want?
- slychiu - 08-20-2010
You can use flags to do this which are set or cleared by the X10 On or off responses
If you are using X10 to arm to night mode, before you do the arm action you can check the 3 flags to determine if the related zones should be bypassed, then do the arm to Night action
Note that auto arm action willl auto-bypass the open zones, so the bypass zones action will be not needed. If you dont want to auto bypass you must use the Key arm actionb, not the auto-arm action
I have just understand what a \'Flag\' is, and i am beginning to see what really CP9000 can do!
I think CP9000 is really a great machine!
Now, finally i am able to use my security system as i want!
I want to thank all the Cytech staff for the great help in installing and configuring.
Your system is really amazing and above all, you are a great staff, because your help has always been fast and useful.
Many many thanks to all!
You have replyed just when i was typing my last message....
I have understood many things today about configuring CP9000......
Surely i will need some other things to learn, but now, basically everything works!
[user=1]slychiu[/user] wrote:
Quote:You can use flags to do this which are set or cleared by the X10 On or off responses
Thanks. You miust be quite clever to have done so far by yourself without any previous training!
- slychiu - 08-21-2010
To convert your ccl file to cclx for Comfigurator 3, open configurator 3, do File Open and select ccl file. This loads your old file, then Save As cclx file
- emabonacchi - 08-21-2010
I can not use Comfigurator 3 because my laptop has an old operative system (Win 98).
I have a newer laptop with Win Xp, but it has not the serial port and trying to use the usb-adapter, the communication with ucm doesn\'t works.
But it seems comfigurator2 is ok at the moment.
I will search a solution in order to be able using Comfigurator3 in the future, but now i am intrested to make all the system works.
Now i am studying about language and vocabulary because i would like to have the  answering machine working as i want.
At the moment i am a really happy customer!
