Fingerprint reader - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Access Control (https://www.comfortforums.com/forum-43.html) +--- Thread: Fingerprint reader (/thread-1588.html) |
- ident - 09-27-2009 In your test bed, the Number of UCMs is set to 2 and the FPR is ID 2? Then the setup is correct - ident - 09-27-2009 Can you monitor activity using the Bus Monitor when the fingerprints are read, and send us the log. This wil tell whether anything was sent from the UCM to Comfort when a fingerprint was ready The Bus monitor is in Tools in Comfigurator. This requires a UCM05. Select the COM port for connection Enter your user code in the UCM Login box on the bottom right then press Start You should see activity on the main window when the fingerprint is read Press Halt and Save and send us the file - technik23 - 09-28-2009 I\'m using comfigurator 3 The UCM I/O monitor doesn\'t show anything when I trigger the FP with a valid fingerprint. Could it be a problem with this batch of readers? - ident - 09-28-2009 I dont know what the problem could be. We will send two new FPRs and UCMs. After you verify them please return two sets so we can check what went wrong - ident - 09-28-2009 I spoke too soon. I just noticed in the Bus Monitor display screen that the port is inactive and the UCM Login window is blank. You need to enter your code eg 1234 in the password window before pressing Start - technik23 - 09-28-2009 That is your image. I ws logged in on the monitor and was detecting other processes - ident - 09-28-2009 Oops. We will send the replacements then - technik23 - 09-28-2009 Thanks We have five FPRs in all and non of them work. If you could send the replacements to me, and I return them as soon as I can replace them Thanks - ident - 09-28-2009 Now I cannot believe that 5 FPRs do not work! It is not possible as all were tested before shippong. There must be a mistake somewhere. We will send 1 FPR with UCM connected up for you to verify Can you send your ccl or cclx file for checking, to support@cytech.biz - technik23 - 09-28-2009 Seriously they don\'t work! I\'m quite happy for you to send 1 to try I\'ll send you one from the testbed which you can try. Where should I send it? The only variable we have not discussed is SW8 but it shouldn\'t affect things according to the manual. SW 8 1 and 2 are shorted. The key is that D2 and D3 show no activity when the FP is read so it would seem that there is no data coming from the Touchstar units. I\'ve just tested the outputs from teh Touchstar and there is nothing. |
