Threads: 1
hi have a problem on a comfort 1 with the flashing message light. This used to reset after messages deleted, but is now constantly flashing when there are no messages.
any ideas ?
thanks
Threads: 888
Do a system reset by pressing the reset button or in Transfer > Reset. This should clear the flashing message led.
Threads: 1
yes that does reset the light temporarily, however the problem occours every time after a message has been left.
any ideas.
Threads: 888
What is your firmware version?
When you listen to a new message the message led goes off when there are no more messages
Can you tell me the exact sequence of events?
Is this a new problem with an old Comfort I that you are just experienceing, ie was it working properly before? Can you tell me what may have changed?
Threads: 1
hi firmware is outside 4200811
the message light is reset after engineer reset,
when a message is left it flashes correctly
when messages are deleted it will not turn off the flashing message light
an engineer reset will fix this until a message is again left.
According to the user this has only just started to happen, the only thing that has occoured is a doorphone interface and fermax panel has replaced a standard comfort door phone.
Threads: 262
blipblap, can you email me privately at support@cytech.biz and let me know you contact details, we will get the problem fixed for you.
regards
Threads: 35
What is the solution to this problem?
Ultra II Firmware-Week 5.121, comfigurator v2.2.3
Cheers
Threads: 35
I can confirm that the LED is now coming on when a message is left but has gone full circle and now won\'t go out.
After installing the new firmware I rang from outside and left a message. This turned on the MSG LED and pressing # said there was a message for user 1.
Signed in as user 1 and deleted the message. the MSG led stayed on and the screen says new message. pressing # states that there are no new messages.
I have deleted all messages and it is still doing this on all keypads.
I am sure a reset will clear it but that is no help.
Cheers
