11-01-2015, 03:17 PM
I have an internal sounder to wire in. Can I please just confirm the connections before I commence.
The connections is has are-
R- Negative siren trigger. Apply 0V to activate sounder
M- Negative low volume siren trigger. (keypad) 0v to activate
ST- Negative strobe trigger. Apply 0v to activate strobe
H+ Permanent positive hold off supply, 12vdc nominal
H- permanent negative hold off supply
RTN Negative tamper return
Would I be correct with.
R- This would go to the output connection
ST- Rather than use the comfort strobe connection (as this is already used with an external sounder) could I jumper across to R- so both the sounder and strobe activate together?
H+ just to the comfort 12v supply (not the 12v on the output)
H- to comfort negative.
Is this OK or would I better connecting it straight to bell and strobe outputs.
http://www.elmdene.co.uk/files/ins/int500s-00.pdf
Also the instructions state I need to pass through a ferrite sleeve before connecting. Is this needed with comfort?
Thanks.
Thanks.
