First attempt to upgrade UCM over the bus Succeeds
Downloaded Comfigurator 331, and wanted to upgrade the UCM\'s which are already at 6.002
Fired up Comfigurator, did a system information check (works fine) then proceeded to do the upgrade firmware, and selected \"over the bus\"
The program crashed with an exeption - any ideas ?
Loaded again, and this time it goes through the process. Try again, the same error appears. V. odd
Same error on another PC trying to scan for modules in comfigurator
Upgrading over the bus works for UCMs and SEMs that are not directly connected to Comfort, like UCM/CBus, UCM/KNX etc
If you want to upgrade UCM/Eth, UCM/USB, UCM/232, KT03 you have to connect to them directly and choose \"for UCM or KT03 direct to PC\"
Ident, when thinks you to release firmware 6.x for UCM/GSM and UCM/KNX?
We will next release Comfort firmware version 6 which supports the Bus upgrading of the GSM, Cbus, KNX etc, and then the external UCM version 6 firmware
On this page - http://comfortforums.com/forum92/2409.html
It states \"For Comfort, Slaves and \"external\" UCMs ie GSM, CBUS, KNX, Velbus, Universal, where the firmware is 6.000 and above, the firmware can now be upgraded via Comfort Bus\"
So my original questions still stands.
1. Comfigurator errors
2. It refuses to upgrade over the bus, despite showing up in the upgradeable list in comfigurator.
That\'s strange as I\'ve been steadily upgrading both my testrig system and my live system with 6.xxx for a couple of weeks now and have not seen the problems you are having either with 3.3.0 or 3.3.1, and I\'ve been upgrading via Ethernet too. I\'ve upgraded both UCM and ULT this way.
Are you still getting that exception then as per your first post or have you moved onto another issue now?
I just did a few scans too as I write this and can\'t get it to crash.  Could I suggest running scan with the I/O monitor window open to see if it always crashes on the same response?
Could a firewall be blocking anything?
What are the modules that show up in the list to be upgraded, and which did you select to upgrade when you saw this problem?
Just the Universal UCM pops up in the list @ 6.003
