Comfigurator 2.1.0
The new Comfigurator 2.1.0 has been released.
V2.1.0
Bug fixes
  • Handle missing default template file saved in Registry
  • Use correct defaults for Vocab and Voice settings when converting to different DspType
  • Save currently selected combobox value if exiting while editing
  • Allow right-click to terminate combobox editing
  • Fix problems exporting/importing responses with references to IR codes
  • Sort responses with numbers > 999 correctly
  • Fix problem reading file with uncommented action codes in response
  • Increase download timeout to cater for delays due to high Comfort activity
  • Ensure number of timers is adjusted correctly when converting between filesystems
New features
  • Support for branch action codes, removing restrictions on use of IF/THEN/ELSE
  • Support ANNOUNCE WORDS action in Response Wizard
