cwm, index.htm can't appear.
IP before  10.0.0.16
IP new  192.168.0.10
I already change the new IP address using http://10.0.0.16/admin.htm. (Comfort Web Module Administration). In menu display I chose Module Setup. In the IP address and Net mask, I change it with the new IP address 192.168.0.10, Net mask 255.255.255.0, Port 80, and Pass-through port 10001.
Internet Connection I chose LAN connection. In LAN connection I include Gateway IP : 192.168.0.1 ( my router IP address ) Name Server 1 IP : 202.133.0.188,  Name Server 2 IP : 202.133.1.5, when finish this section CWM going to reset, after CWM reset finish I check the IP address already change to 192.168.0.10.
When I go to test http://192.168.0.10/ the browse is error 404.
When I go to ftp://192.168.0.10/ is can go in. I already check index.htm file is inside ftp.
regard
akai
Is CWM working with 10.0.0.16 before the IP change?
If yes, do a check from http://192.168.0.10/admin.htm (if you are able to access the page), to see if the settings are correct?
If all settings are correct, do a power reset on the CWM (ie.  switch off the power adapter.  After a few seconds, switch it on again).  Check if it works this time.
If still not working, then do a cross-cable between your PC and CWM.  That will take away network related problems.
1)  Power off CWM.
2)  Connect a network cross-cable between your PC and CWM.
3)  Power on CWM.
4)  Access http://192.168.0.10 (your pc should be in the same subnet, ie. having a different IP address but same network mask)
Hope this helps.
hai...
I already use this setting before this, but it still same problem.
Now my connection already in cross cable betwen touchscreen computer and CWM.
I don\'t understand what you mean by that.  I will contact you privately to help you out.
