X10 transmission problem
I noticed that in some circumstances, especially when disarming, X10 commands have some issues.
For example, when i come back to home i disarm the Comfort. There is a response associated to \"disarm\" event, turning on a light.
Often, instead of turning on this light, Comfort turns on another light on the same house code, or starts irrigation on another house code.
This issue has started with fw 5.115.
I\'ve Comfort Ultra Gen 2
Is it a Comfort issue, or maybe X10 transceiver issue?
Thanks.
Can you use the Comfigurator Monitor Mode to Monitor the messages when this happens. The X10 commands transmitted by Comfort will be reported. This will indicate if Comfort is sending the correct X10 commands
There were no changes to the X10 function in 5.115. Perhaps you could also switch back to 5.113 and verify if the same problem occurs
Ok, i will do it.
In the meantime, this is the response associated to \"Disarm\" event
If  SecurityMode = AwayMode Then
    X10 Abatjours-Letto On
    X10 Presa-Climatizz On
    If Flag LuceAutoCucina <> 0 Then
        X10 Luce-Soggiorno On
    End If
End If
I suspect not enough idle time between X10 commands; maybe do x10 transceiver misunderstand command sequences ?.
I give a try with monitor and i let you know, but for me, Comfort is sending x10 commands correctly.
Thanks.
