Comfigurator 2.2.2 is a maintenance release to fix known bugs in 2.2.1
Released 18 Sept 2007
Bug fixes
New Features
Known Issues
The default Engineer Code is 6789.
[color=\"black\"][size=\"1\"][size=\"2\"]In order to enable engineer Code without pressing F0, do the following
[/size][/size][/color][/color][/size] 1 Start Comfigurator
2 Select [Transfer] [Monitor I/O] so that it is ticked.
3 Select [Transfer] [System Information]
4. If asked for a password enter a normal user code, not the engineer code.
The system info window pops up, if it does not then your cannot do anything until that issue is resolved.
5 Click [OK] on the system info window to get rid of it.
6 Now in the long one line ( command line field of Comfigurator) type DA5C01 followed by carriage return. (This means Do Action - Enable Engineer)
You should see the following in the log window.
Tx: <STX>DA5C01<CR>
Rx: <STX>PS01<CR>
Rx: <STX>RA00<CR>
The PS01 is the system reporting that engineer code is now enabled.
7 Now do a standard [Transfer] [Download PC> Comfort], and all should be well with the world.
[size=\"2\"][color=\"red\"]
[/color][/size]
Bug fixes
- Validate name in new zone, zonetype and alarmtype dialogs
- Fix problem uploading/downloading sensor feedback in control menu
- Show referenced sensor responses
- Fix problem with Dynalite commands shown as SendRS232
- Update references when alarmtype or zone name is changed
- Fix incorrect Ulti action descriptions
- Fix crash when executing very long response
- Fix problem with progress > 100% in event log upload
New Features
- Login not required for Firmware Download
- Login Window for Download has warning \"Press F0 and enter Engineer code on keypad\"
Known Issues
- Alarm Types Names not uploaded correctly (Comfort > PC)
- Misc Events > User Responses are not shown as Referenced responses
- Reminders are not shown as References
- No Sunrise/Sunset available for Vietnam
- X10 Responses and housecode for FS31 and FS18 revert to default after saving the ccl file
- Reminders 9 to 16 on/off settings download wrongly
- Open Door Action allows UCM ID, not Door Station ID
- Editing Tuning Parameters incorrect limits applied
- In Security > CMS, if the Account Code is less than 6 digits, the leading digits 00 are added. eg 4567 becomes 004567. Change using the keypad Engineer Menu 4 for Phone Numbers, select Phone 1 or 2 , 1 for Type CMS, 1 for Monitoring Station Code and enter the account code and # key, eg 4567#. This bug was from Comfigurator 2
Tx: <STX>DA5C01<CR>
Rx: <STX>PS01<CR>
Rx: <STX>RA00<CR>
[/color][/size]
