Now that all the flash parts are available for Comfort G2, itââ¬â¢s likely that Iââ¬â¢ll be doing[font=\"Times New Roman\"] [/font]some major work on the panel again soon. As ever, the biggest PITA with this is that as soon as I power-down the system, my main siren goes off. Clearly I therefore need to provide a 12V hold-off to the siren to shut it up whilst Iââ¬â¢m working on the panel. Normally, I frig some Heath-Robinson-esque arrangement that involves disconnecting the siren cable from the SIREN terminals on the mainboard, and twisting the bare wire-ends round a temporary supply (usually a wall-wart, since I donââ¬â¢t usually have enough slack cable to pull them down to reach the battery)...
Frankly, this is pants.... it takes a couple of minutes to complete the above bodge, during which the siren is blaring, and it almost always[font=\"Times New Roman\"] [/font]ââ¬Åfalls offââ¬Â during the work in progress, setting it off again... (and It takes a minute or two to reverse the bodge at the end as well).... Net result, - my neighbours arenââ¬â¢t very happy with me!
Therefore, before I embark on the next round of work on the panel, I want to sort out an easy, reliable, and[font=\"Times New Roman\"] [/font]straightforward way of[font=\"Times New Roman\"] [/font]managing the siren hold-off. Iââ¬â¢m envisaging something that just involves flicking a switch mounted somewhere inside the main enclosure.
When work commences, the requirements always include:
- [font=\"Times New Roman\"] [/font]cutting the mains power
- [font=\"Times New Roman\"] [/font]disconnecting the battery from the mainboard
- [font=\"Times New Roman\"] [/font]connecting a hold-off supply to the siren
Clearly, it would be a simple matter to break the cable from the battery, & insert a switch to cut the input to the mainboard.[font=\"Times New Roman\"] [/font]I also want it to switch the battery terminals over to supplying the hold-off to the siren...[font=\"Times New Roman\"] [/font]ââ¬â Presumably, I shouldnââ¬â¢t connect the battery to the siren cables whilst theyââ¬â¢re still connected to the SIREN terminals on the mainboard, - as otherwise Iââ¬â¢ll be pumping 12V INTO the mainboard on those siren terminals...[font=\"Times New Roman\"] [/font]ââ¬â not sure what the effect of that might be....
So Iââ¬â¢m after suggestions how to achieve this easily... ââ¬â Iââ¬â¢d need to supply both + and ââ¬â to the siren, so I guess Iââ¬â¢d need to switch *both* battery terminals, even though Iââ¬â¢d only need to cut one of them to remove battery power from the mainboard.... so I guess at least I need a DPDT switch on the battery output leads to switch them both from the mainboard to the siren... ââ¬â what about the issue of the 12V then being connected to the SIREN outputs? ââ¬â could I just put a diode in the + lead between the switch & the SIREN connection?
The layout I'm contemplating is shown in the attached JPG. The 12V FROM the battery is connected to the centre poles in this diagram, - the BAT & SIREN points are the terminals on the mainboard[font=\"Times New Roman\"] [/font]where the battery & siren are connected to Comfort.[font=\"Times New Roman\"] [/font] When switch is in[font=\"Times New Roman\"] [/font]position 1 (leftmost), the + and[font=\"Times New Roman\"] [/font]ââ¬â terminals from the battery are connected to the usual battery in terminals on the mainboard, as per normal. When switched to position 2 (rightmost), the battery is disconnected from the battery in terminals on the mainboard (thus achieving 1 of the 3 requirements), the 12V battery supply[font=\"Times New Roman\"] [/font]is instead rerouted to the cable going off to the siren, thus providing the hold-off required to keep it silent. The diode is inserted[font=\"Times New Roman\"] [/font]in the cable[font=\"Times New Roman\"] [/font]before it enters the SIREN terminal such that current is able to flow OUT of the terminal, but not IN to it.....
Does this make sense?[font=\"Times New Roman\"] [/font]ââ¬â would this be feasible?[font=\"Times New Roman\"] [/font]ââ¬â any thoughts?[font=\"Times New Roman\"] [/font]ââ¬â alternative suggestions?
TIA
Paul G.
TIA
Paul G.
